Traceroute and multiple links
fsebera
Level 4
Level 4
I have 6 links to a neighbor router.
All links are equal cost, operational and passing traffic.
When I traceroute to the next hop loopback address, traceroute ONLY uses 3 of the six paths.
ANYONE know why?
OER-Master1#sh ip eigrp top
IP-EIGRP Topology Table for AS(90)/ID(172.26.3.1)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 172.26.0.14/32, 1 successors, FD is 128256
via Connected, Loopback0
P 172.26.0.15/32, 4 successors, FD is 130816
via 172.26.2.2 (130816/128256), GigabitEthernet0/0.2
via 172.26.4.2 (130816/128256), GigabitEthernet0/0.4
via 172.26.5.2 (130816/128256), GigabitEthernet0/0.5
via 172.26.6.2 (130816/128256), GigabitEthernet0/0.6
via 172.26.1.2 (130816/128256), GigabitEthernet0/0.1
via 172.26.7.2 (130816/128256), GigabitEthernet0/0.7
OER-Master1#traceroute 172.26.0.15
Tracing the route to 172.26.0.15
1 172.26.6.2 0 msec
172.26.5.2 4 msec
172.26.4.2 0 msec
OER-Master1#
Hello Franck,
4 paths is the default for EIGRP
have you added
router eigpr ASN
maximum-paths 6
otherwise only 4 successors are installed in the routing table
in other words
until you don't see all 6 paths in the ip routing table with sh ip route you cannot be sure they are all used.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Franck,
traceroute defaults to use three probes for each TTL so it cannot discover 6 paths.
you need to use extended traceroute and to modify the number of probes sent to a number >= 6 to see this.
that is
traceroute
Hope to help
Giuseppe
Hi Giuseppe,
I did not know this fact.
Excellent THANKS.
I could only get the Cisco IOS to use 4 links. Since this is new IOS in a lab environment and not critical -YET, I will accept the results for now.
BTW, I specified 6, 12, 24 and 100 probes and received the same results.
IOS on Cisco 3845 router.
flash:c3845-advipservicesk9-mz.124-11.XJ4.bin"
Protocol [ip]:
Target IP address: 172.26.0.15
Source address: 172.26.0.14
Numeric display [n]:
Timeout in seconds [3]:
Probe count [3]: 100
Minimum Time to Live [1]:
Maximum Time to Live [30]:
Port Number [33434]:
Loose, Strict, Record, Timestamp, Verbose[none]:
1 172.26.4.2 4 msec
172.26.2.2 0 msec
172.26.6.2 0 msec
172.26.5.2 4 msec *
172.26.2.2 0 msec
172.26.6.2 0 msec
172.26.5.2 4 msec
172.26.4.2 0 msec *
172.26.6.2 0 msec
172.26.5.2 0 msec
172.26.4.2 4 msec
172.26.2.2 0 msec *
172.26.5.2 0 msec
172.26.4.2 0 msec
172.26.2.2 4 msec
172.26.6.2 0 msec *
172.26.4.2 0 msec
172.26.2.2 0 msec
172.26.6.2 4 msec
172.26.5.2 0 msec *
172.26.2.2 0 msec
172.26.6.2 0 msec
172.26.5.2 4 msec
172.26.4.2 0 msec *
172.26.6.2 0 msec
172.26.5.2 0 msec
172.26.4.2 4 msec
172.26.2.2 0 msec *
172.26.5.2 0 msec
172.26.4.2 0 msec
172.26.2.2 4 msec
172.26.6.2 0 msec *
172.26.4.2 0 msec
172.26.2.2 0 msec
172.26.6.2 4 msec
172.26.5.2 0 msec *
172.26.2.2 0 msec
172.26.6.2 0 msec
172.26.5.2 4 msec
172.26.4.2 0 msec *
172.26.6.2 0 msec
172.26.5.2 0 msec
172.26.4.2 4 msec
172.26.2.2 0 msec *
172.26.5.2 0 msec
172.26.4.2 0 msec
172.26.2.2 4 msec
172.26.6.2 0 msec
--snip--
ctrl-shift 6
These are the interfaces on the next hop router where 172.26.0.15 resides.
OER-Master1#ping 172.26.1.2
Sending 5, 100-byte ICMP Echos to 172.26.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
OER-Master1#ping 172.26.2.2
Sending 5, 100-byte ICMP Echos to 172.26.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
OER-Master1#ping 172.26.4.2
Sending 5, 100-byte ICMP Echos to 172.26.4.2, timeout is 2 seconds:
OER-Master1#ping 172.26.5.2
Sending 5, 100-byte ICMP Echos to 172.26.5.2, timeout is 2 seconds:
OER-Master1#ping 172.26.6.2
Sending 5, 100-byte ICMP Echos to 172.26.6.2, timeout is 2 seconds:
OER-Master1#ping 172.26.7.2
Sending 5, 100-byte ICMP Echos to 172.26.7.2, timeout is 2 seconds:
OER-Master1#
Hello Franck,
have you added
router eigpr ASN
maximum-paths 6
in other words
Hope to help
Giuseppe
THANKS,
I thought the EIGRP default was 6. :(
OER-Master1(config)#router eigrp 90
OER-Master1(config-router)#maximum-paths 16
OER-Master1(config-router)#end
OER-Master1#
Protocol [ip]:
Probe count [3]: 6
1 172.26.7.2 0 msec
172.26.6.2 4 msec
172.26.5.2 0 msec
172.26.4.2 0 msec
172.26.2.2 4 msec
172.26.1.2 0 msec
OER-Master1#
