NCM Task Template
May 7th, 2009
Within NCM 1.3, in the Run Command Script window, I can choose to use a 'Task CSV template', (below).
Does anyone know how the scriptfield1/scriptfield2/scriptfield3 columns can be used? I would like to be able to either put device specific commands in those fields, or, be able to pull those fields as a variables from an advanced command script. I could not find any reference to these fields in the NCM user manual.
DavidTimpany Thu, 05/21/2009 - 07:01
the "scriptFieldx" are the actual names of variables you have created in your command script (without the surrounding $'s).
