Wavelink Avalanche Server
May 7th, 2009
Does anyone have any experience using the Wavelink Avalanche Server to manage hundreds of 7921 phones in a large WLAN environment?
Does it work and it is cost-effective?
migilles Fri, 05/08/2009 - 16:26
You can see the 7921G Deployment Guide for further info on using Wavelink.
Wavleink is recommended for post deployment device management. But for deployment phase you can use our standalone config utility for that.
Our configuration utility doesn't support PEAP or EAP-TLS at this time though as the only method to import a certificate to the phone is via the webpage.
