Which CSS does unity uses for Message Notification
Answered Question
May 7th, 2009
Hello Experts,
When we use Message Notification to HomePhone for a subscriber, we configure some of the unity ports to do Message Notification
Besides on the VoiceMail port at CUCM we have 2 CSSs, the one for the port and the one for the DN of the port
The CSS for the port has to be public for susbcribers phones to get there
The CSS for the DN of the port is normally the restricted one.
Which of those CSSs does Unity uses when Message Notification to a HomePhone?
Thank you!
Correct Answer by Jaime Valencia about 8 years 1 month ago
VM ports use in 1st place the one from the port and then the one from line, opposed to the behavior of phones.
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 05/07/2009 - 12:04
  • Cisco Employee,
  • Hall of Fame,
    2011
java
