NVRAM, Flash Memory question on ASA
May 7th, 2009
Silly, and embarassing question.
On the ASAs, is the whole principal regarding flash memory, RAM and NVRAM the same?
Meaning, like on switches and routers, the Flash memory holds the OS, the NVRAM holds the starup config and the RAM loads everything and is used while the device is running.
For some reason, i cant seem to find that answer.
Thanks.
mvsheik123 Thu, 05/07/2009 - 12:01
  • Gold, 750 points or more
That is correct (you already know the answer)..:-)In addition RAM also holds xlate etc..
hth
MS
