Display topology Services in client with IExplore 7 or Firefox 2.0
May 7th, 2009
I can't open TopologyServices view, I'm using internet exploret 7.0 and firefox 2.0 with Java ™ 6 update 5 in the client.
In firefox 2.0
-Starting java
-connecting to Campus Manager Server…please wait
-and then Send window message
"cannot connect to ANI server...unknown Error ..."
In IExplore 7.0
-firts I have to click download file,
-starting java
-begin connenting to Campus Manager Server…please wait, and finally the same error to firefox
jtalbaugh Thu, 05/07/2009 - 12:40
What version are you using?
In LMS 2.6 you have to use an older version of Java (Java 1.4.2) I believe.
Not sure about browser version (IE6 works).
Martin Ermel Fri, 05/08/2009 - 01:44
as jclarke mentioned on this forum yet, the most likely cause is that the client cannot connect to the server on TCP ports 42342 and 43242 because of a firewall (e.g. local firewall on the client) or accesslist that prevents this.
For a test try to connect to the server on these ports:
telnet 43242
telnet 42342
Also the name of the LMSserver must be resolvable on the client.
Emonroy89 Fri, 05/08/2009 - 14:30
thanks ....TCP ports aren't problem, I saw the name of server isn't added in DNS server, and thats why don't contact it the client.
