05-07-2009 01:42 PM - last edited on 03-25-2019 07:50 PM by ciscomoderator
Is there any licenses, other thean the Software Feature PAK, that are required for upgrading from 5.1 to 7.0. I thought I needed to do something with the DLU's as well in this case.
Solved! Go to Solution.
05-07-2009 03:16 PM
the only change is that you will need to get your Feature License which allows you to start the ccm services, you carry your DLUs and node licenses from 5.X
java
if this helps, please rate
05-07-2009 03:16 PM
java
