FXO Card Installation
May 7th, 2009
hi guys,
I have CCME with Four FXO port card .. i am configuring FXO port first time .. below is my voice-port config:
voice-port 0/2/0
supervisory disconnect dualtone mid-call
compand-type a-law
cptone SA
connection plar 101
caller-id enable
and my dial-peer config is
dial-peer voice 1 pots
preference 1
destination-pattern 9T
port 0/2/0
with above config i am not able to make outgoing call .... how to troubleshoot FXO lines ....
for PRI or E1 we normally use debug isdn q931, what about FXO configuration ????
if there is some mistake in my config can any please correct it or share the running config ???
thanks in advance
Kenneth Mohammed Thu, 05/07/2009 - 14:40
  • Silver, 250 points or more
The problem is with your dial-peer 1. Pots dial-peers by default strip explicitly matched digits. You need to have a forward-digits command under the dial-peer. Example:
description Local 7 Digit Dialing
destination-pattern 9.......
port 0/2/0
forward-digits 7
dial-peer voice 2 pots
description Local 10 Digit Dialing
destination-pattern 9[2-9].........
port 0/2/0
forward-digits 10
description Long Distance
destination-pattern 91[2-9].........
port 0/2/0
forward-digits 11
In the above examples, the 9 will be stripped from the dialed digits, and the dial-peer will forward the specified amount of digits depending on which dial peer is matched. If you are just going to use the "9T" destination pattern, then you would just add "forward-digits all" under the dial peer, which will strip the 9, and forward the rest of the dialed digits. Make one of these dial-peers for each of the voice ports that you are using for outbound calls. Also, FYI, the command to debug FXO is "debug vpm signal".
Hope that helped, if so please rate.
jijo.paul Thu, 05/07/2009 - 22:56
hi this is the configuration
conf t
voice-port 0/2/0
connection plar 101
exit
destination-pattern 9.T
port 0/2/0
forward-digits 7
port 0/2/0
forward-digits 10
port 0/2/0
forward-digits 11
and pls add prefix 9 to dialed no before dialing external call it will work.
hope this helps.pls rate
jijo
kelvin.blair Mon, 05/11/2009 - 05:37
Just to add to the fine information you already have. The debug commmands to use with FXO/FXS cards is "debug vpm signal". This will tell you alot especially when paired with "debug voice dialpeer inout"..
