UCCX and CCM 6.0 Integration
May 7th, 2009
Hye......
I installed CCM 6.1 and UCCX. i create all the mobility extension on CCM and users accordingly. UCCX showing my users detials and i configuared all the things accordingly. But when i login my phone the UCCX real time monitoring always shows logged out.
Dennis Mink Fri, 05/29/2009 - 07:51
In CUCM, under user management-->end user have you selected the IPCC extension?
(if you are using the agent desktop, log in and check again, make sure you put yourself on available)
