ASA command "crypto map"? Different than PIX code...
May 7th, 2009
This command in older PIX 515e doesn't have any other arguments, what is the ASA 8.0.4 looking for and why? I don't have ASDM access as I'm running IE8.
ASA-5505-InternalMedicine# config t
ASA-5505-InternalMedicine(config)# crypto map outside_map 62 ipsec-isakmp
ERROR: % Incomplete command
Snippet of config;
crypto map outside_map 62 match address InternalMedicine
crypto map outside_map 62 set peer 209.X.Y.Z
crypto map outside_map 62 set transform-set ESP-AES-256-SHA
handsy Thu, 05/07/2009 - 23:50
That command "crypto map outside_map 62 ipsec-isakmp" is deprecated for static crypto maps. It is only used for dynamic maps nowadays. It took me ages to work that out too :)
Btw, why don't you use the ASDM application that installs itself to your desktop?
