05-07-2009 09:28 PM - edited 03-14-2019 04:03 AM
We have IPCC setup located at central location and rest of two locations (eg. site A, site B) are conneted over wan where agents get log on to CTIOS application. When agents get log on to site A only, they can receive the calls properly. But when agents get log on to site B only, calls get dropped while transferring to agent and agent gets an error message on his softphone as "Agent state set to Not Ready because calls routed to you were not recieved." What could be the issue?
05-08-2009 08:00 AM
Could be your agents are getting set to not ready because of a RONA scenario? When you say 'transfer', do you mean agent to agent or agent to queue? Or do you mean 'routed' to agent? Also - if you log into a site B device with a site A account do you still have the issue? Do you have device targets and labels configured for everything?
Also - do you ever see the agent go into 'reserved'?
Robb
05-09-2009 02:45 AM
I mean to say routed to agent. Agent goes into reserved and then we get the error message. When agents at both sites log on at same time and agents at site A are busy, new incoming call goes into queue instead of getting routed to agents at site B and their softphone goes into 'not ready' State
05-09-2009 02:54 AM
I viewed in router log viewer also and found that the extension of that IP Phone is selected and no error log generated for that extension.
