05-07-2009 09:50 PM - edited 03-06-2019 05:36 AM
HI , Welcome for All
I am putting two series widely in my new network , which are 500 and 3500 series , but here I am getting confused to select the Interface Module , Should I opt GLC-SX-MM or WS-G5484
Praveen 9212 506 503
05-08-2009 03:41 AM
500 supports only GLC-SX-MM and GLC-LH-SM
GLC-SX-MM is SFP while WS-G5484 is GBIC they both operate in ordinary multimode fibre
You may opt to GLC-SX-MM for 500 and WS-G5484 for 3500. But you should tell us the exact model of you 3500.
Here is the link http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
05-08-2009 04:11 AM
First to get my Greetings !!!
I was biased these , provided URL having great Info ,
By the Way I select to put
3560G-24TS ,3560E-12SD
By your information I will select GLC-SX-MM for All Switches
Thnaks for Support
