Policy-Based Routing on 3560 switches
phil_carter
Runing a 3560 on IOS c3560-ipservices-mz.122-25.SEE3.bin (which states PBR is available in Feature Navigator), and also with routing SDM template.
SLHX3530#sh sdm prefer
The current template is "desktop routing" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
number of unicast mac addresses: 3K
number of IPv4 IGMP groups + multicast routes: 1K
number of IPv4 unicast routes: 11K
number of directly-connected IPv4 hosts: 3K
number of indirect IPv4 routes: 8K
number of IPv4 policy based routing aces: 512
number of IPv4/MAC qos aces: 512
number of IPv4/MAC security aces: 1K
However, it will not allow the below route-map config to be used in a PBR statement when applied to a layer-3 physical interface:
route-map STIG-traffic-to-FW permit 10
match ip address 2
set ip next-hop 10.247.250.142
set interface Null0
access-list 2 remark For_STIG_traffic_route_map_to_FW
access-list 2 permit any
int f0/8
ip address 10.139.145.13 255.255.255.248
ip policy route-map STIG-traffic-to-FW
The below error message appears:
000064: May 7 18:45:22: %PLATFORM_PBR-3-UNSUPPORTED_RMAP: Route-map STIG-traffi
c-to-FW not supported for Policy-Based Routing
It will only accept the below route-map:
This seems to semi-work, with mixed results. It does not however allow full design needed. Can anyone advise why this doesn't work with the IOS/config above, and if there is a quick easy solution (upgrade to a different IOS level with proven results)?
Phil
Jon Marshall
Phil
Unfortunately not all route-map commands are supported on Catalyst switches. The "set interface" command is not supported on the 3560 even with the latest IOS - 12.2(50)SE -
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_50_se/configuration/guide/swuncli.html#wp1088139
Jon
found out it's a hardware restriction.... many thanks.
