Load balancing-Help
May 8th, 2009
hello all,
We have 2 offsite locations site A and site B which are connected to MPLS cloud from where it connects to two data centres at onsite.Offshore sites has bandwidth of 512 Kbps each.These sites acts as backup to each other.We have a local loop connecting ths 2 sites.
Now we have moved our users from siteA to siteB and we wanted to utilize the MPLS link at siteB for siteA traffic.
we want both links at site A to be active-active.
attached the connecivity diagram.
our LAN is behind a pix firewall and two routers are in HSRP.Default static route in pix points to the virtual IP.
The MPLS routers are managed by service provider.
Please advice how we acheive the load balancing with minimal changes in this scenario.
Sam
Danilo Dy Fri, 05/08/2009 - 03:00
  • Blue, 1500 points or more
Try putting IP GRE Tunnel between Site A and Site B thru MPLS (between routers of Site A and Site B at the top of the diagram). This way you have more control on what you want to do.
sarsamivel Fri, 05/08/2009 - 03:50
Hi,Can you explain a bit more on this.I am not quite familiar with GRE tunnels.
Our requirement is to load balance the two links and will i acheive in this way ?
Thanks.
