ASA (policy) NAT help
whiteford
I think this might a be policy NAT required, but I have never tried this before.
On our LAN we have a subnet 192.168.100.x/24 and this need to get to an IP range of 10.100.0.32/27 which is a remote company network, tyhe thing is they also have a network on 192.168.100.x/24 so I want 192.168.100.x/24 to be NAT'ed to 192.168.90.0/24 only if going to this netork.
Possible
24 Replies 24
andrew.prince
Level 10
Level 10
Yes this is possible - you need to use PolicyBased NAT
HTH>
Do you have an example of this.
Inside range he is on is
192.168.100.x/24 and he need to get to 10.100.0.32/27
I want him to be seen as 192.168.90.x/24 or 192.168.90.240 if easier?
The config would be something like:-
access-list <> extended permit ip <> <
static (inside,outside) <> access-list <>
HTH>
access-list policy_NAT permit ip 192.168.100.0 255.255.255.0 host 10.100.0.32
static (inside,outside) 192.168.90.240 access-list policy_NAT
If there is a match in the ACL 'policy_NAT' then the 192.168.100.x address will be translated to 192.168.90.240
hi,
When adding "static (inside,outside) 192.168.90.240 access-list policy_NAT
I seem to get the error:
global address overlaps with mask
Check your ACL.
Use NAT instead:
global (outside) 1 192.168.90.240
nat (inside) 1 access-list policy_NAT
Can host 10.100.0.32 be a range 10.100.0.32/27 ?
Yes
Yes, just take out :
host 10.100.0.32
and replace with
10.100.0.32 255.255.255.224
Tried this but it didn't work, this my fault the interface where this network lives is off acn interface on the ASA called "DMZ3":
access-list policy-nat-2 permit ip 192.168.100.0 255.255.255.0 10.100.0.32 255.255.255.224
global (outside) 2 192.168.90.240
nat (inside) 2 access-list policy-nat-2
You need to detail the error, or why you say it didn't work.
Have you forced the connection from the 192.168.100.0/24 to the 10.100.0.32/27 network?
Does 'show xla' give you a translation?
Sorry that was very brief of me.
I have added this as you know:
the 192.168.100.x is on the inside and 10.100.0.32/27 is on the DMZ3 interfcae on the ASA which is were this WAN is installed to this remote network.
Let me look at the NAT translations.
Then you need to change nat (<>) 2 access-list policy-nat-2
