05-08-2009 03:23 AM - edited 07-03-2021 05:33 PM
In the data sheet for the 2100 it states that "Provides eight 10/100 Ethernet ports, intended to support a combination of access points and redundant LAN uplinks"
My question is.. How do you configure the redundent uplinks as aparently the 2100 doesnt support LAG (Link aggregation)..
Any ideas?
Many Thanks
Solved! Go to Solution.
05-08-2009 07:03 AM
yes, so long as you configure the switch ports and your interfaces properly you shoud be fine. If the port one is lost, it will resort to the back up port.
yes, you can configure your controller ports in that way.
Always test it before releasing into production
if you found this post helpful please rate it ...
05-08-2009 03:44 AM
When you configure your dynamic interface under the CONTROLLER tab. You select a port in which you want that traffic cross. Under that you can also select a BACKUP port should the other port ever go down ...
05-08-2009 06:57 AM
Excellent, Thanks.
So i can uplink the primary and backup ports to seperate switches?
I'm thinking that i would home all interfaces to the same priamry and backup ports and then uplink each port to a different switch. There isnt really a need to try and load balance as the traffic volumes are quite low.
What do you think?
05-08-2009 07:03 AM
05-08-2009 07:33 AM
Thanks for the great replies. Really appreciate your advice.
