Voice Gateway outside firewall, CUCM inside
May 8th, 2009
If I have the voice-gateway for a CUCM outside the firewall, what NAT statement and port are needed for the configuration of the firewall?
Overall Rating: 4 (1 ratings)
sachinraja Fri, 05/08/2009 - 09:42
Hello Steven
Following URL lists the ports used by CUCM with various components:
Is there any access-restriction applied on the inside interface of a firewall ? If so, you will have to open up appropriate ports as listed on the pdf.. make sure you open UDP 16384-32767 for communication between voice gateway to CUCM on the outside interface, for return voice traffic..
you can just give a normal static statement, which does not nat the traffic.. eg, if the CUCM has as ip, u can give
static (inside,outside) netmask
or the other way around by natting the gateway IP address..
Hope this helps.. all the best.. rate replies if found useful.
