QoS Tagging
May 8th, 2009
Would it be possible that a QoS tagging is lost as it traverses between directly connected interfaces of two switches.
What possible reason a dscp marking is stripped on the ingress interface?
Thanks.
Overall Rating: 4 (2 ratings)
Collin Clark Fri, 05/08/2009 - 08:01
  • Purple, 4500 points or more
The only way I can think of is if you remapped the markings, which I don't think is possible ingress on a layer 2 switch.
If you have "mls qos" enabled - BUT you want to keep the DSCP value in the IP header and NOT have the switch re-write it according to it's internal DSCP mapping tables then configure:-
"no mls qos rewrite ip dscp"
By default a switch WILL re-write and DSCP/COS values unless told not to.
HTH>
bolshoi.88 Sat, 05/09/2009 - 02:16
Thanks guys. Would there be service interruptions when you apply this commands?
Thanks.
bolshoi.88 Mon, 05/11/2009 - 07:59
Can this applied to a Cisco 4500?
Any equivalent command?
Thank you.
bolshoi.88 Mon, 05/11/2009 - 08:01
Is this the same as no qos rewrite ip dscp?
thank you.
