05-08-2009 05:34 AM - edited 03-06-2019 05:37 AM
I am looking for an article about how to configure T1 connectivity between two Cisco 2600 routers.
05-08-2009 06:28 AM
What protocol and other settings need to be configured on the Cisco routers?
05-08-2009 06:36 AM
George
That's really for you to say. Is it frame-relay, ATM, serial P2P - HDLC/PPP ? Depending on what L2 protocol you are using to connect the configuration details will be very different from each other.
Jon
05-08-2009 06:43 AM
I am using P2P, so would I use PPP? What other settings need to be configured? Is there a Cisco article about this type of connection?
05-08-2009 06:59 AM
I will be using a Kentron CSU/DSU.
05-08-2009 09:29 AM
I would like to find an article for configuring a Cisco 2600 series router with ppp, to work with a Kentrox CSU/DSU.
05-11-2009 03:40 AM
Configuring the router with PPP, along with some form routing protocol, or static routing will be necessary.
