Jaime Valencia Fri, 05/08/2009 - 05:57
  • Cisco Employee,
  • Hall of Fame,
    2011
configure a translation pattern on CUCM to reroute the call
java
if this helps, please rate
jcsmith96 Fri, 05/08/2009 - 07:41
how would I configure it, do you have an example.
Jaime Valencia Fri, 05/08/2009 - 11:29
  • Cisco Employee,
  • Hall of Fame,
    2011
they're pretty straightforward
Translation Pattern -> your DID
Called party transform mask -> to where you want to send the call
just make sure the inbound CSS from your GW has the partition from the translation pattern and the CSS from the translation pattern can reach the route pattern you're going to use.
make sure called party has whatever is needed to make the call ie 9 for outside calls
java
paolo bevilacqua Sun, 05/10/2009 - 21:09
  • Hall of Fame,
    Founding Member
What about configuring CFA on a DN.
paolo bevilacqua Mon, 05/11/2009 - 09:33
  • Hall of Fame,
    Founding Member
You don't need to put a phone, just the profile and CFA from http interface.
