What does New Config. not yet ACTIVE mean?
May 8th, 2009
I've noticed several routers with IMA that have "New Config. not yet ACTIVE"
What does this mean?
router>sh atm int atm0/0
Interface ATM0/0:
AAL enabled: AAL5 , Maximum VCs: 255, Current VCCs: 0
Maximum Transmit Channels: 0
VCIs per VPI: 256,
Max. Datagram Size: 4528
PLIM Type: DS1, TX clocking: LINE
Cell-payload scrambling: OFF
0 input, 0 output, 0 IN fast, 0 OUT fast, 0 out drop
Avail bw = 1536
hadbou Sun, 05/17/2009 - 19:06
  • Bronze, 100 points or more
As I suspected, the message is not significant as it does not show the actual state of the
interface. As a matter of fact, that command is completely irrelevant for monitoring the
status of the interface or of the IMA group. Therefore, it cannot even be consider a
cosmetic bug, but simply another instance of the multiple IOS commands that, even though available, don't have any implication in the correct functionality of a feature (the IMA circuit in our particular case)
In an IMA circuit, the individual interfaces don't record any statistics, as they are no
longer considered independent, but part of a group instead. For that reason, "show atm
int atmx/y" or "show int atmx/y" don't show (and are not supposed to show) any traffic
statistics.
For troubleshooting or monitoring IMA circuits we can use the commands below:
show int atmx/imay
show ima int atmx/y
show ima int atmx/y detail
show ima int atmx/imay
That line is a bogus message from the IOS. Actually, that command is not used for troubleshooting/monitoring IMA circuits.
