route-map not getting applied
daredevil24
We have 2 3550 switch with same ios 12.1(22)EA4. I do not have any issue while applying route-map on secondary switch.
But when i try to apply the route-map on to the vlan, does not give any error and when i se the config of the vlan i do not see the route-map configuration on the int vlan 2.
ip access-list extended test
permit ip host 172.25.128.250 host 62.173.225.52
route-map expedia permit 1
match ip address test
set ip next-hop 192.168.128.18
int vlan 2
ip policy route-map test
any idea.
Thanks.
Satish
5 Replies 5
rais
Level 7
Level 7
I think route-map name is expedia. Is that the problem or a typo?
Thanks.
sorry, the config was :
route-map test permit 1
int vlan 2
Even this is not working.
regards,
Hi:
What do you mean it is not working?
How do you know? What test are you running? Can you post the complete outputs?
frosalia
ip policy route-map name should expedia, not test. test is the name of the acl you are matching against.
Satish
Are both switches using the same template to control switch resources? Can you post the output of show sdm prefer from both switches?
Rick
Rick
