translation pattern to same office using same access code
Answered Question
May 8th, 2009
I am having problems trying to create a translation-rule that allows me to use *2 to go to an office that actually has two different PRI ranges.
Here is what I have done:
rule 2 /[*]2\(....\)/ /1303381\1/
rule 3 /[*]2\(6...\)/ /1303385\1/
I want the user's to be able to dial *2+4 digit extension to each office. *2 goes to one office with different DID ranges. In rule 2 the DID range is 3XXX in rule 3 the DID range is 6XXX.
Every test matches rule 2 and not rule 3.
How can I accomplish this?
Correct Answer by Jaime Valencia about 7 years 10 months ago
you cannot expect rule 3 to be matched, they're created in order of preference and first one to match is used
.... has any number in 6XXX in it and is before, so it's expected you will never hit 3rd rule
reverse the order of statements or if the other range is 3XXX configure 3... on #2
this is like an ACL, configure statements from particular to general
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Fri, 05/08/2009 - 11:42
  • Cisco Employee,
  • Hall of Fame,
    2011
java
