ACS Appliance and ACS View device support for LMS3.1
May 8th, 2009
I did a search and didn't see any reference. But I would like to manage both my ACS appliances as well as the ACS View appliance via LMS. I have configured w/ snmp, but I cant locate device package for either product line. LMS thinks the ACS appliance is a Call Manager! Any info would be great.
Joe Clarke Fri, 05/08/2009 - 11:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
ACS manageability is not currently supported in LMS. I know of no plans to add support.
rtuttle Mon, 05/11/2009 - 12:16
Ok, well that doesn't leave any room for alternative interpretation now does that Joe? :)
So even though I can configure the devices for snmp, it gives nothing. And at this point, never will.
Ok, Thanks
Joe Clarke Mon, 05/11/2009 - 12:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can add the device to LMS, but LMS is already configured to treat the Windows sysObjectID as a Call Manager, so you won't get specific ACS management capabilities. You will, however, be able to do basic mibII management of the ACS server in RME.
