Site-2-Site VPN odd config
May 8th, 2009
Today I had to troubleshoot a VPN configuration and I've never seen VPN configured this way. I'll need someones help.
whit this config i see vpn tunnel established but i am not sure the interestin traffic is going trought the tunnel or is routed to default gateway to internet
This is the config:
interface Ethernet0
description Internet Faceing Address
nameif outside
security-level 0
ip address aaa.bbb.173.242 255.255.255.0
ospf cost 10
interface Ethernet1
description LAN Faceing Address
nameif inside
security-level 100
ip address 172.25.110.42 255.255.254.0 standby 172.25.110.40
ospf cost 10
same-security-traffic permit inter-interface
object-group network ABC
description Systems With Access to VPN
network-object host 172.25.100.93
network-object host 172.25.101.93
access-list outside_access_out remark To ABC
access-list outside_access_out extended permit ip aaa.bbb.173.160 255.255.255.240 host 216.229.154.50 log
access-list outside_access_out extended permit ip aaa.bbb.173.160 255.255.255.240 host 216.229.154.12 log
access-list outside_access_in extended permit ip host 216.229.154.50 aaa.bbb.173.160 255.255.255.240 log
access-list outside_access_in extended permit ip host 216.229.154.12 aaa.bbb.173.160 255.255.255.240 log
access-list inside_access_out extended permit ip object-group ABC host 216.229.154.12 log
access-list inside_access_out extended permit ip object-group ABC host 216.229.154.50 log
access-list outside_cryptomap_iron extended permit ip aaa.bbb.173.160 255.255.255.240 host 216.229.154.50
access-list outside_cryptomap_iron extended permit ip aaa.bbb.173.160 255.255.255.240 host 216.229.154.12
static (inside,outside) aaa.bbb.173.166 172.25.100.93 netmask 255.255.255.255
static (inside,outside) aaa.bbb.173.167 172.25.101.93 netmask 255.255.255.255
static (outside,inside) 172.25.100.93 aaa.bbb.173.166 netmask 255.255.255.255
static (outside,inside) 172.25.101.93 aaa.bbb.173.167 netmask 255.255.255.255
access-group outside_access_in in interface outside
access-group outside_access_out out interface outside
access-group inside_access_out out interface inside
route outside 0.0.0.0 0.0.0.0 aaa.bbb.173.254 1
route inside 172.25.100.0 255.255.254.0 172.25.111.254 1
crypto map IronRules 10 match address outside_cryptomap_iron
crypto map IronRules 10 set peer 216.229.152.17
crypto map IronRules 10 set transform-set Iron
crypto map IronRules 10 set security-association lifetime seconds 28800
crypto map IronRules 10 set security-association lifetime kilobytes 4608000
bamnocadmin Mon, 05/11/2009 - 05:18
I think you need to post full config (with NAT and group-policy). Also, you can see if traffic goes through tunnel with "sh cry ip sa".
Thanks.
