Regulatory domain mismatch !!!
May 9th, 2009
Hi netpros,
I am having an issue when upgrading several access points to LWAPP. The a radio is unable to associate to the controller due to regulatory domain mismatch. I have read that vesion 5.X supports multiple regulatory domains. How can I enable this feature on my controller which is running 5.1.163.0 version ?
Below is the message I am gettting
"AP on the 802.11a radio with Base Radio MAC X.X.X.X.X.X(APXXX) is unable to associate.
The regulatory domain configured on it '-A' does not match the controller's regulatory domain: -N"
Your help is much appreciated !!!
Overall Rating: 3 (2 ratings)
Fernando_Meza Sun, 05/10/2009 - 23:18
Hi Fella5,
Appreciate your input but the Controller and the access points are installed in Australia, The Country Code on the Controller is already configured for AU. I am suspecting it has to be with the domain hard-coded on the AP when it was originally purchased. The model number of the AP is AIR-AP1242AG-A-K9 .. any idea how I can identify what is the domain configured/hard-coded on it ? There is a broken link on Cisco which could give the answer. Any help is much appreciated.
Cisco broken link
http://www.cisco.com/application/pdf/en/us/guest/products/ps5861/c1650/cdccont_0900aecd80537b6a.pdf
Leo Laohoo Mon, 05/11/2009 - 15:53
Hi Fernando,
I think it's because of the FCC Compliance code. The "A" or "N" means that your model, which has the "A", is FCC Compliant. You should've gotten the non-compliant version, the "N".
Contact Cisco and ask them if they are able to replace it with something else. How did you wind up with a US version for Australia is a puzzle by itself.
Hope this helps.
Fernando_Meza Tue, 05/12/2009 - 15:13
Hi leolaohoo
"How did you wind up with a US version for Australia is a puzzle by itself". You know I have inherited it so I can't comment on this.
If the AP are for US then it should be Ok to configure AU and US on the controller. I will do that .. some channels might not work .. I will have to test that.
Cheers,
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
