7921 stuck at Locating Network Services
Answered Question
May 9th, 2009
Trying to set up a new 7921 phone with a Cisco AP (1131). I have a laptop that can see the SSID and connect with no issues. The 7921 just keeps cycling the same message "Locating Network Services".
I took the phone and sat it top of the AP and still nothing.
Any help would be greatly appreciated.
Correct Answer by migilles about 7 years 9 months ago
From your config, you are doing Open + WEP, so set the phone to that, enter the 26 digit Hex WEP key for key 1 and set the ssid to WR-VOICE. Ensure there is no space at the end.
If you enter site survey mode, you should be able to see the AP as long as the SSID is correctly input.
Then just have to worry about the authentication piece.
Ensure the phone has 1.3(2) loaded.
Should order a -A phone if in the Americas, but if you have a -W phone, then you need to enable world mode (802.11d) on the AP.
You would enter a command like the following:
interface dot11radio 1
world-mode dot11d country US both
See the 7921G Deploiyment Guide for other country codes if necessary.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/6_0/english/deployment/guide/7921dply.pdf
Correct Answer by SJessulat_2 about 7 years 9 months ago
what encryption and Authentications did you set up on the AP?
Pasting the confiuration or part of it would help a lot.
And what are the settings on the Phone?
Greets,
Sebastian
Overall Rating: 4.5 (2 ratings)
Correct Answer
SJessulat_2 Sun, 05/10/2009 - 22:24
Greets,
Sebastian
Correct Answer
migilles Mon, 05/11/2009 - 09:14
rbill1967 Mon, 05/11/2009 - 13:16
Besides the extra that you gave me and I applied I was missing one simple piece. I forgot to capitalize the spelling of the SSID. Kind of stupid miss, but I finally stumbled upon it.
Working Beautifully.
