Dial plan
May 9th, 2009
Can enyone tell me how to make i new dial plan, i,m new in this and i have no idea how to make it :).
Jaime Valencia Sat, 05/09/2009 - 18:32
the 1st thing would be searching CCO for dial plan to get information
Cisco Unified Communications Manager (CallManager) Dial Plan Deployment Guide
Dial Plan
there really is nothing much to this, search downloads for available dial plans per version, if the one you're looking for isn't there, google is your best friend to get examples and create your own route patterns
BTW, since you don't mention what you're using or versions i'm just going to assume this is CUCM 7.X
if this helps, please rate
