CME 4.1 Custom Directory
May 9th, 2009
Hello, We are rolling out CME 4.1 at remote offices and we would like to create a custom company directory and host it on a server so all the CME sites can access it. I thought it would be as simple as creating a XML file that looks like this
<CiscoIPPhoneDirectory>
<Title>Directory title goes here</Title>
<Prompt>Prompt text goes here</Prompt>
<DirectoryEntry>
<Name>The name of the directory entry</Name>
<Telephone>The telephone number for the entry</Telephone>
</DirectoryEntry>
</CiscoIPPhoneDirectory>
and enter this command (url directories http://x.x.x.x/directory.xml) under telephony-service. But when I press the directories button on the phone I am getting a XML parse error 4. Am I missing a step somewhere? Any help is appreciated.
paolo bevilacqua Sun, 05/10/2009 - 20:36
  • Hall of Fame,
    Founding Member
If you enable and capture the default directory output, you should be able to see how to format your properly.
davex4285 Mon, 05/11/2009 - 05:39
Thanks for the tip.
Alright, I enable the local directory and I am able to view it using the IP Phones but I do not see a way to capture the directory file. I don't see a file in flash. Any ideas?
paolo bevilacqua Mon, 05/11/2009 - 08:54
  • Hall of Fame,
    Founding Member
Use an XML browser, or other PC-based tool.
