Change CAS IP address
Answered Question
After I had added CAS server to CAM domain, can I change the IP address of CAS anymore? Do I need to regenerate the SSL certificates? I am using temporary SSL certificate atm.
Thank you.
Correct Answer by nomair_83 about 8 years 2 months ago
Yes u will need to regenerate the temp cert unless u are using name instead of IP of CAS (not sure about name but for IP changes u have to)
Overall Rating: 5 (1 ratings)
Correct Answer
nomair_83 Mon, 05/11/2009 - 10:32
  • Bronze, 100 points or more
