NBAR and match protocol
Answered Question
May 10th, 2009
is it necessary to turn on NBAR for command "match protocol" even the protocol is very command protocol "smtp", "DNS", etc?
if no, when shall we turn on NBAR?
Correct Answer by mahmoodmkl about 8 years 2 months ago
as soon as u enter the config in the MQC and if u want to use the above statement NBAR is automatically turned on.
If u dnot want to use NBAR then u can use access-lists.
Mahmood
Overall Rating: 5 (1 ratings)
Correct Answer
mahmoodmkl Sun, 05/10/2009 - 00:40
  • Gold, 750 points or more
Mahmood
Joseph W. Doherty Sun, 05/10/2009 - 04:28
"is it necessary to turn on NBAR for command "match protocol" even the protocol is very command protocol "smtp", "DNS", etc? "
No, as Mahmood also notes.
"if no, when shall we turn on NBAR?"
If you need to do NBAR protocol discovery.
