Call manager Express 7.1 and Unity express 3.2
Answered Question
May 10th, 2009
When i configure Unity express 3.2 initialization wizard, i can see GUI for Call manager and not for CME , Is there any version related issue or do i have to use Unity express which is compatible with Call manager Express 7.1 ?
Correct Answer by rob.huffman about 7 years 8 months ago
Hi Janaka,
**This should show (when integrating with CME);
Application mode: CME or CCME
You can download the proper license for CME from the page I have linked below :)
You seem to be trying to use the wrong License file;
For Callmanager (which I think you have used)
cue-vm-license_12mbx_ccm_3.0.2.pkg
License information package for a 12-mailbox version of the Cisco Unity Express with VoiceMail application that works with Cisco Unified CallManager. For all Cisco Unity Express modules: AIM-CUE, NM-CUE, NM-CUE-EC & NME-CUE.
For Callmanager Express - CME (which I think you need)
cue-vm-license_12mbx_cme_3.0.2.pkg
License information package for a 12-mailbox version of the Cisco Unity Express with VoiceMail application that works with Cisco Unified CallManager Express. For all Cisco Unity Express modules: AIM-CUE, NM-CUE, NM-CUE-EC & NME-CUE
From this link;
http://www.cisco.com/cgi-bin/tablebuild.pl/cue-302-licenses
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Sun, 05/10/2009 - 06:42
Hi Janaka,
From this link;
Hope this helps!
Rob
janakamolagoda Mon, 05/11/2009 - 00:56
Hi Rob,
What you mentioned is correct.The current license is CCM.We need to buy the CCME.
Is there a way i can download CCME license as cisco TAC not helping much on this.
Can i install this license using clean installation method ?
Janaka
