enable password change through LMS 3.0.1
Answered Question
May 10th, 2009
I want to change enable secret on all the switches,if i changed with a net config will the LMS be able to complete the job and if does then will be able communicate with the devices for next or i have to go common services>Device and Credential Admin>Editing Device Credentials,and i have to change manually enable secret for all the switches.
Also i want to remove the secondary credentials from all the devices in common services(DCR)how can i do it?
I have installed
Common Services 3.1.1
Resource Manager Essentials 4.1.1
Correct Answer by Joe Clarke about 7 years 11 months ago
Yes, if you use the Enable Password template, the enable secret value will be automatically updated in DCR as that device's enable password. You will not have to do any manual DCR update.
Go to Common Services > Device and Credentials > Device Management, and select all the devices, then click Edit Credentials. Clear the fields you do not want to be populated, then click Finish when done.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Sun, 05/10/2009 - 10:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
