ISIS routing update filter
May 10th, 2009
How to filter the specific prefixes from IS-IS routing update sending to all neighbor or specific neighbor? for flat ISIS or multi level ISIS design!
Devang Patel
Laurent Aubert Mon, 05/11/2009 - 06:33
If the prefix is part of ISIS domain, you can apply the no isis advertise-prefix on the interface:
If you are redistributing this prefix from another routing protocol then you have the classic route-map you can attach to your redistribution statement.
One thing you can't do is to filter for a specific neighbor. ISIS is a link-state protocol so every routers must have the same topology view.
Giuseppe Larosa Tue, 05/12/2009 - 08:41
Hello Devang,
being IS-IS link state there are limited actions that are possible.
You can hide the details of some specific routes using the following:
build a L2 IS-IS adjacency (different nets on R1 and R2)
declare the interfaces that are associated to the subnets you want to hide as level-1 only.
the default both for the process and for the links is to be L2/L1.
With a setup like this R2 doesn't learn the details of a L1-only prefix on the direct link with R1.
This can lead to R2 learning the prefix from another path.
This happens because interfaces L1-only will be missing from the L2 LSP built by R1 and passed to R2 on the L2 only direct link.
Hope to help
devang_etcom Wed, 05/13/2009 - 11:28
Thanks for your reply! finally no any way to achieve the routing update filter in ISIS. We can filter adj but not updates.
Devang Patel
