How to get PoE status information of 4510RE via SNMP?
May 10th, 2009
we use a WS-C4510R-E with several PoE blades.
With "show power capabilities" we can check the used and available power of the complete chassis, with "show power module" we can check the used power of the modules.
Does anybody know how we can get this information via snmp rather what are the corresponding MIBs/OIDs?
We already checked the following MIBs but did not get any output from the 4510:
CISCO-POE-PD-MIB (1.3.6.1.4.1.9.9.414)
CISCO-POWER-ETHERNET-CAPABILITY (1.3.6.1.4.1.9.7.412)
CISCO-POWER-ETHERNET-EXT-CAPABILITY (1.3.6.1.4.1.9.7.406)
CISCO-POWER-ETHERNET-EXT-MIB (1.3.6.1.4.1.9.9.402)
Best Regards,
Thorsten Steffen
dwbielawa Mon, 05/11/2009 - 03:41
I would suggest trying the standard mib POWER-ETHERNET-MIB. When I check PoE on my 3750's that works for me.
POWER-ETHERNET-MIB 1.3.6.1.2.1.105
Hope this Helps
Daniel Bielawa
thorsten.steffen Fri, 05/22/2009 - 06:28
Hi Daniel,
I tested this MIB but I also get no information back from dem switch. Any further idea?
Best Regards,
Thorsten Steffen
