Syslog
May 11th, 2009
HiAll,
I have to do syslog rotation in the LMS 3.1.
The logs are saved in C:, size is 100,000.Once this log size is exceeds. This logs will save to D:/,size 500000,revision is 10.Kindly advice me any workaround for this solution.
Joe Clarke Mon, 05/11/2009 - 08:55
You haven't really described a problem here. You have just mentioned your logrot configuration. Are you saying logrot is not working with this configuration?
digisridhar Mon, 05/11/2009 - 22:03
If u want u can decrease the revisions to 10 and check if the Log Rotation happens. Also u can schedule an immediate Job for the same.
Also do let us know as to ur problem to help.
Sridhar
prakashj Mon, 05/11/2009 - 23:14
Hi clarke,
The logrot is not working ,Once the primary disk log message is exceeds The logs is not going to backup directory.
prakashj Mon, 05/11/2009 - 23:16
Hi clarke,
Joe Clarke Tue, 05/12/2009 - 09:07
Post your NMSROOT/objects/logrot/logrot.conf, and the output of:
NMSROOT/bin/perl NMSROOT/bin/logrot.pl -v
