FWSM and routers between FWSM and MSFC
May 11th, 2009
Hi, I have a FWSM in trasparent mode and some routers in "not protected" vlan, between FWSM and MSFC. For the server in the "protected" vlan, is better to have only the default route to the MSFC or to have some route specific entries to the routers ?
thanks
Jon Marshall Mon, 05/11/2009 - 05:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Renato
Shouldn't make any difference as far as i can see. The key thing is to ensure you don't route around the FWSM and with the other routers being in the unprotected vlan then you won't.
As a side issue though would it not be better to just leave the server with a default gateway of the MSFC and let the MSFC take care of routing packets to the other routers ?
Jon
r.spiandorello Mon, 05/11/2009 - 07:39
Jon, I aggree to use the default route to the MSFC, and MSFC take care to route packets to the routers on the unprotected vlan, on the same vlan where FWSM bridges packets to the server in the protected vlan.
In your mail, I don't understand the key thing I expect to be "ensure you don't route around the FWSM and with the other routers being in the protected vlan".
thanks
