CRASH EDWAAS BOX
May 11th, 2009
I noticed that my cisco waas box (wae-512-k9) has crashed and all efforts to restore it has proved abortive. I have copied some error messages to help in determining what the problem might b. Besides that it is obvious that the disks on the device has failed is there another way to restore the box besides the procedures in the config guides?
ERRORS
No directory /local/local1/./!
Logging in with home = "/".
System is initializing. Please wait...
Please use 'show disks details' to monitor system status.
Disk based software not installed.
Some applications may not run correctly!
NO-HOSTNAME(config-if)#ip add
sh: /ruby/bin/assign_interface_irqs.pl: /usr/bin/perl: bad interpreter: No such file or directory
NO-HOSTNAME#sh disks details
Physical disk information:
disk00: Not present or not responding
disk01: Not present or not responding
Mounted file systems:
MOUNT POINT TYPE DEVICE SIZE INUSE FREE USE%
No RAID devices present.
Disk encryption feature is disabled.
Daniel Laden Tue, 05/12/2009 - 14:36
  • Cisco Employee,
Sounds like you have disk failures.
-Dan Laden
CSCO11117246 Tue, 06/30/2009 - 03:55
Hi Dan,
The waas device has been working without physical hard disks in any of the two SATA slots. If a standard SATA2 hdd is inserted in any of the slots will reinstall succeed? As long as the device is supposed to support a standard SATA2 hdd I believe it should. Right?
