Cannot Load the IOS of a 7206vxr Router
May 11th, 2009
I want to change the IOS of my Cisco7206vxr Router which have a NPE-G2 installed in it.I want to change the IOS to c7200p-ipbase-mz.124-15.T7.bin . But after I upload the new file into the router the router continiously saying the following error messages :-
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
loadprog: bad file magic number: 0x0
boot: cannot load "cisco2-C7200"
System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Socket jumper: not present Failsafe jumper: present = normal
FPGA revision 0x00000026
C7200 platform with 2095104 Kbytes of main memory
Readonly ROMMON initialized
boot: cannot load "disk2:c7200p-ipbase-mz.124-15.T7.bin"
string is disk2:c7200p-ipbase-mz.124-15.T7.bin
boot: cannot load "disk2:"
Lastly the prompt which I am getting is Router(boot)>.
What is the actual problem and how can it be solved.
Any help is most welcome.
Abhishek Pal
Paolo Bevilacqua Mon, 05/11/2009 - 07:39
  • Hall of Fame,
    Founding Member
Is disk2 right? Probably not.
Check and reset boot variables as needed: "env" "BOOT=xxxx", etc.
alliancebroadba... Tue, 05/12/2009 - 05:01
Formatting bootflash: and disk2: and then re-transferring the boot image and IOS resolved the issue.
Thanks and regards.
Abhishek
shivlu jain Mon, 05/11/2009 - 23:33
  • Silver, 250 points or more
hi
try to use "tftpdnld -r" in rommon mode. It will upload the ios in ram. Because the problem you are facing most probably with the bad flash or try to format it.
regards
shivlu jain
