Variable QoS?
jplowick3
Is there a way to setup variable QoS for a traffic flow? I have an 85 Mbps metro-ethernet WAN connection between two sites. One side has a Cisco 3745 router, the other has a Cisco 2821 router. We just recently installed two SANs (one at each site) and they are mirrored. I would like to be able to setup a max bandwidth usage of 50Mbps for the replication of the SAN. And then bump it back down to 25 Mbps while backups are taking place. Right now I'm using the "traffic-shape" command to limit traffic from the SAN to 25 Mbps by matching its IPs. If I left it at 50 Mbps, then that leaves about 30 Mbps for backups which slows down my backups.
In the future, I can probably get away with just having the 25 Mbps limit. But for now, I have to replicate several terabytes of data, so the more bandwidth I can give it the better.
6 Replies 6
jwdoherty
What would the variable depend on? How would you distinguish between normal SAN and backup SAN?
A simpler approach, I would suggest, would be just setting the bandwidth reservation for a minimum, not a maximum.
I.e., instead of capping SAN replication bandwidth, set its priority relative to your backups to obtain bandwidth ratios between them as you desire.
The SAN uses iSCSI to replicate data, so I just match those IPs for limiting the bandwidth. The variable is really the time of day. So during the day, I run at 50 Mbps for the SAN, then at night it drops to 25 Mbps while backup are running. The reason I was looking for capping the SAN bandwidth was that it will consume the entire link if it's not throttled back. When that happens, response time for users drops considerably.
I had originally thought of something along these lines, but not sure if it will work.
access-list 101 remark Match SAN traffic
access-list 101 permit ip host host
access-list 102 remark Match Backup traffic
access-list 102 permit ip host host
class-map match-all SAN-MirrorView-Traffic
match access-group 101
class-map match-all Backup-Traffic
match access-group 102
policy-map PM-Limit-SAN-MirrorView
class SAN-MirrorView-Traffic
bandwidth percent 30
class Backup-Traffic
bandwidth percent 60
class class-default
fair-queue
I believe you can build policy maps on timed based ACLs, but from what you describe, don't believe you need to.
Try something like this:
policy-map MetroEthernet85Mbps
class-default
!allow for Ethernet overhead
shape average 77000000
service-policy PM-Limit-SAN-MirrorView
bandwidth percent 1
bandwidth percent 2
class class-default
fair-queue
interface FastEtherent x
service-policy output MetroEthernet85Mbps
BTW, SAN (and/or backups) using all the bandwidth should not adversely impact other traffic as long as it is treated with little queuing priority.
Thanks. Does the percent value matter? Or is it the just ratio of the numbers?
I had looked into the time-based ACLs too. Would something like this work? The ACLs 101 & 102 would have the time-ranges set match to their class-map names. If the time is outside of the time-range set for an ACL, does it just ignore the ACL?
class-map match-all SAN-Traffic-Day
class-map match-all SAN-Traffic-Night
class SAN-Traffic-Night
class SAN-Traffic-Day
class class-default
fair-queue
The percentage matters as it sets ratios to other traffic. For example
bandwidth percent 3
bandwidth percent 6
bandwidth percent 1
bandwidth percent 2
All the above will set the same ratios relative to each other, but what's the ratio relative to class-default? (BTW, many platforms/IOSs won't accept bandwidth percents that sum more than 75% unless reservation changed.)
Yes, the time-based ACL tied to classes should work. Of course, the policy-map doesn't really realize you're only changing bandwidth allocations for time of day. I.e. you've allocated 90% when you intend (and will effectively obtain with time-based ACLs) 30% or 60%. This can become annoying when you want to explicitly allocate bandwidth to other defined classes.
PS:
If your available downstream bandwidth is less than the interface's, don't forget a parent policy shaper. Otherwise, you'll usually end up (FIFO) queuing at the next bottleneck without the bandwidth allocations you intended. (This could explain poor performance you've seen for other traffic when SAN not capped with shaper.)
Thanks for the info! I'll give the parent policy-map setup a shot and see how it works.
