Cisco 2811 PVDM 32
Answered Question
May 11th, 2009
Hi guys
I am currently trying to configure a 2811 with a PVDM2-36DM and a HWIC-1CE1T1-PRI to allow remote users to dial in using both ISDN and pstn modem access. Is this possible using this combination of WICS?
Correct Answer by paolo bevilacqua about 8 years 2 weeks ago
You do not have "ppp authentication eap" in dialer like you do in group-async.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Mon, 05/11/2009 - 07:21
  • Hall of Fame,
    Founding Member
Yes, it should be possible.
ultra-datel Mon, 05/11/2009 - 07:53
this is the config we are running. we can dial a Windows XP machine in using PSTN no problem, however ISDN will authenticate the link, and then can't negotiate a PPP link
this is the config we are applying
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps log datetime msec show-timezone
service password-encryption
hostname xxx
boot-start-marker
boot-end-marker
card type e1 0 0
logging buffered 4096 informational
enable secret xxxxxx
aaa new-model
aaa authentication login default local
aaa authentication login console local
aaa authentication ppp default group radius
aaa session-id common
clock timezone GMT 0
clock summer-time GMT recurring
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
modem call-record terse
modem country v12 e1-default
modem recovery threshold 10
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp bootp ignore
ip dhcp pool dialinusers
network xxxxx xxxxxx
default-router xxxxx
dns-server xxxxxxx xxxx
no ip domain lookup
isdn switch-type primary-net5
isdn voice-call-failure 0
username xxxxxx password xxxxxx
archive
log config
logging enable
logging size 200
hidekeys
path flash:archeived-config
maximum 14
write-memory
time-period 1440
controller E1 0/0/0
pri-group timeslots 1-31
interface FastEthernet0/0
description "xxxxxx"
ip address xxxx xxxxxx
no ip redirects
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
ip address xxxxx xxxxxx
no ip redirects
duplex auto
speed auto
no cdp enable
interface Serial0/0/0:15
description "D Channel interface for the Primary Rate ISDN"
no ip address
encapsulation ppp
ip mroute-cache
dialer rotary-group 1
dialer-group 1
isdn incoming-voice modem
no fair-queue
no cdp enable
interface Dialer1
no ip address
encapsulation ppp
dialer in-band
dialer idle-timeout 2147482
dialer-group 1
no peer default ip address
no fair-queue
no cdp enable
ppp multilink
interface Group-Async1
description "Global Interface for PRI Dial-In Connections"
ip unnumbered FastEthernet0/0
encapsulation ppp
dialer in-band
dialer idle-timeout 0
async mode interactive
peer default ip address dhcp-pool dialinusers
no fair-queue
no ppp chap wait
ppp multilink
group-range 0/386 0/421
ip route xxxx xxxx FastEthernet0/0
ip route 1xxxx xxxx FastEthernet0/0
ip route 1xxx xxx FastEthernet0/1
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
no cdp run
radius-server host xxxxx auth-port 1645 acct-port 1646
radius-server timeout 10
radius-server key xxxxxx
control-plane
line con 0
login authentication local
line aux 0
exec-timeout 0 1
no exec
transport output none
line 0/386 0/421
login authentication console
modem Dialin
modem autoconfigure discovery
rotary 1
terminal-type length
transport input all
autoselect during-login
autoselect ppp
line vty 0 4
exec-timeout 0 1
no exec
transport input none
scheduler allocate 20000 1000
many thanks in advance
paolo bevilacqua Mon, 05/11/2009 - 08:14
  • Hall of Fame,
    Founding Member
Does "debug ppp neg" shows anything ?
ultra-datel Mon, 05/11/2009 - 08:49
ay 11 16:44:14.251: Se0/0/0:0 LCP: MagicNumber 0x6F205023 (0x05066F205023)
*May 11 16:44:14.251: Se0/0/0:0 LCP: PFC (0x0702)
*May 11 16:44:14.251: Se0/0/0:0 LCP: ACFC (0x0802)
*May 11 16:44:15.175: Se0/0/0:0 LCP: I CONFREJ [ACKsent] id 52 len 17
*May 11 16:44:15.175: Se0/0/0:0 LCP: MRRU 1524 (0x110405F4)
*May 11 16:44:15.175: Se0/0/0:0 LCP: EndpointDisc 1 ras001 (0x130901726173303031)
*May 11 16:44:15.175: Se0/0/0:0 LCP: O CONFREQ [ACKsent] id 53 len 10
*May 11 16:44:15.175: Se0/0/0:0 LCP: MagicNumber 0x24583098 (0x050624583098)
*May 11 16:44:16.099: Se0/0/0:0 LCP: I CONFNAK [ACKsent] id 53 len 8
*May 11 16:44:16.099: Se0/0/0:0 LCP: AuthProto EAP (0x0304C227)
*May 11 16:44:16.099: Se0/0/0:0 LCP: O CONFREQ [ACKsent] id 54 len 10
*May 11 16:44:16.099: Se0/0/0:0 LCP: MagicNumber 0x24583098 (0x050624583098)
*May 11 16:44:17.019: Se0/0/0:0 LCP: I CONFNAK [ACKsent] id 54 len 8
*May 11 16:44:17.019: Se0/0/0:0 LCP: AuthProto EAP (0x0304C227)
*May 11 16:44:17.019: Se0/0/0:0 LCP: O CONFREQ [ACKsent] id 55 len 10
*May 11 16:44:17.019: Se0/0/0:0 LCP: MagicNumber 0x24583098 (0x050624583098)
*May 11 16:44:17.939: Se0/0/0:0 LCP: I CONFNAK [ACKsent] id 55 len 8
*May 11 16:44:17.939: Se0/0/0:0 LCP: AuthProto EAP (0x0304C227)
*May 11 16:44:17.939: Se0/0/0:0 LCP: O CONFREQ [ACKsent] id 56 len 10
*May 11 16:44:17.939: Se0/0/0:0 LCP: MagicNumber 0x24583098 (0x050624583098)
*May 11 16:44:18.863: Se0/0/0:0 LCP: I CONFNAK [ACKsent] id 56 len 8
*May 11 16:44:18.863: Se0/0/0:0 LCP: AuthProto EAP (0x0304C227)
*May 11 16:44:18.863: Se0/0/0:0 LCP: O CONFREQ [ACKsent] id 57 len 10
*May 11 16:44:18.863: Se0/0/0:0 LCP: MagicNumber 0x24583098 (0x050624583098)
*May 11 16:44:19.047 UTC: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to N/A N/A
*May 11 16:44:19.783: Se0/0/0:0 LCP: I CONFNAK [ACKsent] id 57 len 8
*May 11 16:44:19.783: Se0/0/0:0 LCP: AuthProto EAP (0x0304C227)
*May 11 16:44:19.783: Se0/0/0:0 LCP: O
followed by
CONFREQ [ACKsent] id 58 len 10
*May 11 16:44:19.783: Se0/0/0:0 LCP: MagicNumber 0x24583098 (0x050624583098)
*May 11 16:44:20.703: Se0/0/0:0 LCP: I CONFNAK [ACKsent] id 58 len 8
*May 11 16:44:20.703: Se0/0/0:0 LCP: AuthProto EAP (0x0304C227)
*May 11 16:44:20.703: Se0/0/0:0 LCP: O CONFREQ [ACKsent] id 59 len 10
*May 11 16:44:20.703: Se0/0/0:0 LCP: MagicNumber 0x24583098 (0x050624583098)
*May 11 16:44:21.623: Se0/0/0:0 LCP: I CONFNAK [ACKsent] id 59 len 8
*May 11 16:44:21.623: Se0/0/0:0 LCP: AuthProto EAP (0x0304C227)
*May 11 16:44:21.623: Se0/0/0:0 LCP: O CONFREQ [ACKsent] id 60 len 10
*May 11 16:44:21.627: Se0/0/0:0 LCP: MagicNumber 0x24583098 (0x050624583098)
*May 11 16:44:22.547: Se0/0/0:0 LCP: I CONFNAK [ACKsent] id 60 len 8
*May 11 16:44:22.547: Se0/0/0:0 LCP: AuthProto EAP (0x0304C227)
*May 11 16:44:22.547: Se0/0/0:0 LCP: O CONFREQ [ACKsent] id 61 len 10
*May 11 16:44:22.547: Se0/0/0:0 LCP: MagicNumber 0x24583098 (0x050624583098)
*May 11 16:44:23.467: Se0/0/0:0 LCP: I CONFNAK [ACKsent] id 61 len 8
*May 11 16:44:23.467: Se0/0/0:0 LCP: AuthProto EAP (0x0304C227)
*May 11 16:44:23.467: Se0/0/0:0 LCP: O CONFREQ [ACKsent] id 62 len 10
*May 11 16:44:23.467: Se0/0/0:0 LCP: MagicNumber 0x24583098 (0x050624583098)
*May 11 16:44:24.387: Se0/0/0:0 LCP: I CONFNAK [ACKsent] id 62 len 8
*May 11 16:44:24.387: Se0/0/0:0 LCP: AuthProto EAP (0x0304C227)
*May 11 16:44:24.387: Se0/0/0:0 LCP: Failed to negotiate with peer
*May 11 16:44:24.387: Se0/0/0:0 PPP: Sending Acct Event[Down] id[11]
*May 11 16:44:24.391: Se0/0/0:0 LCP: O TERMREQ [ACKsent] id 63 len 4
*May 11 16:44:24.391: Se0/0/0:0 PPP: Phase is TERMINATING
*May 11 16:44:25.307: Se0/0/0:0 LCP: I TERMACK [TERMsent] id 63 len 4
*May 11 16:44:25.311: Se0/0/0:0 LCP: State is Closed
*May 11 16:44:25.311: Se0/0/0:0 PPP: Phase is DOWN
*May 11 16:44:25.311: Se0/0/0:0 PPP: Phase is ESTABLISHING, Passive Open
*May 11 16:44:25.311: Se0/0/0:0 LCP: State is Listen
*May 11 16:44:25.311 UTC: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0 disconnected from unknown , call lasted 12 seconds
*May 11 16:44:25.315: Se0/0/0:0 LCP: I TERMREQ [Listen] id 1 len 16 (0x6F205023003CCD74000002DE)
*May 11 16:44:25.319: Se0/0/0:0 LCP: O TERMACK [Listen] id 1 len 4
*May 11 16:44:25.507 UTC: %LINK-3-UPDOWN: Interface Serial0/0/0:0, changed state to down
*May 11 16:44:25.507: Se0/0/0:0 LCP: State is Closed
*May 11 16:44:25.507: Se0/0/0:0 PPP: Phase is DOWN
Correct Answer
paolo bevilacqua Mon, 05/11/2009 - 09:03
  • Hall of Fame,
    Founding Member
ultra-datel Tue, 05/12/2009 - 00:20
many thanks worked a treat. must be going blind staring at configs
paolo bevilacqua Tue, 05/12/2009 - 08:12
  • Hall of Fame,
    Founding Member
It's called configuration blindness, and it's very common among engineers.
Thanks for the nice rating, and good luck!
