blade firmware...
May 11th, 2009
Hi All,
while upgrading the firmware on MDS9509 to 3.2, one of the blade (DS-X9016) failed to update the firmware. No error was reported.
Later after looking at the logs, I found the reason was it is a Gen1 blade.
Can I upgrade the fimware on a single blade in a MDS9509..?
peter.ooms Mon, 05/11/2009 - 13:22
If you reload / re-insert the blade, it will usually automatically check and optionally (re)place the module firmware version.
Alternatively, use privileged admin command:
<< reload module x force-dnld >>
where 'x' is the involved module.
I presume, the module was operational and its configuration (merely it's port-settings etc.) were retained in running or start-up config, else you might need to do a reconfig.
Note: a reload will likely disrupts involved traffic.
If the module gives issues, check things out via the
<< show module x recovery-steps >> command to see what it brings.
Trending Topics: Storage Networking
