Connection limiting on ASA
John Blakley Mon, 05/11/2009 - 08:19
  • Purple, 4500 points or more
Manny,
You should be able to lock your customer down in your ftp server. I don't believe you're going to be able to do this in the ASA.
HTH,
John
John Blakley Mon, 05/11/2009 - 09:35
I looked at that option, and it's really hard to say if that's outbound or inbound, or if it can be either. I've never used that option. It's a possibility that you could create an acl, match that acl in a class map, apply the class map to a policy map, and then set the connection limit that would only affect the host that you're wanting to affect.
HTH,
John
