Jaime Valencia Mon, 05/11/2009 - 09:00
  • Cisco Employee,
  • Hall of Fame,
    2011
Hey Tommer
this is most possible:
Creating Route Patterns for Inter-Cisco Emergency Responder Group
Communications
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cer/2_0/english/administration/guide/e911c42.html#wp1046198
Before You Begin
The dial plans must be unique between all Cisco Unified CallManager
clusters supported by a Cisco ER cluster. For example, in the network
shown in Figure 3-1, the extension 3003 can only be defined in Cisco
Unified CallManager cluster CCM-B.
They should all run the same CUCM version, CER must support the number of users you will have and CUCM/CER should not be separated by a WAN.
java
if this helps, please rate
Tommer Catlin Mon, 05/11/2009 - 09:03
  • Green, 3000 points or more
Thanks Java, one of your guys on the PDI team also pointed me to this doc. For whatever reason I couldnt find it.
Thanks!
