How update a LMS 3.1 installation
May 11th, 2009
I've installed a evaluation of LMS 3.1 (CV and RME)on Windows.
My question is how to be sure I've last patchs and do I'really need them. I've had a look on site http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-rme and I've seen lot of patch and update.
My LMS server can't join Internet so what files must I chose?
If I buy today LMS is supply with a CD contain last update? Advices are welcome.
Many Thanks.
Thanks.
Overall Rating: 4 (1 ratings)
Joe Clarke Mon, 05/11/2009 - 09:16
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
For RME, we started posting a consolidated device update bundle. For LMS 3.1, that is http://www.cisco.com/cgi-bin/Software/Tablebuild/doftp.pl?ftpfile=cisco/cw2000/patches/rme/IDU22_RME42_Device_Updates.zip&app=Tablebuild&status=showC2A . Beyond that, the other updates are for specific bugs. IF you find you're running into those bugs, you can download the patches, and apply them.
For other apps like Campus and DFM, the updates are provided as service packs. The latest for LMS 3.1 are CM 5.1.3 and DFM 3.1.4.
If you get a purchased LMS 3.1 DVD now, it will not include the latest device support and service packs. However, you wouldn't need to start from scratch. Once you purchase LMS, just apply the purchased license to your eval server.
jeanpaul.hergott Mon, 05/18/2009 - 07:58
Many thanks for your answer.
About IDU 22 installation: Can I install all devices update in IDU 22 with only one CLI command or I have to use a CLI command for each device I want?
Is LMS 3.1 evaluation and LMS 3.1 on DVD are identical?
Joe Clarke Mon, 05/18/2009 - 08:16
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Yes, you can install all of the packages in the IDU 22 zip file with one PSU command:
PSUCli -p rme -install -src DIRECTORY -all
Where DIRECTORY is the path which contains the individual package files.
