port fast
May 11th, 2009
I have a spaning tree configured on 4 switches that end user are connected to. I have spaning tree enabled, end user are complening of delay of audio coming to the wrk-station , I would like to see if the interfaces are configured for port fast when I do "sho ip int brief" .. there is no indication that in there that will suggest that port is fastport
Overall Rating: 4.3 (6 ratings)
John Blakley Mon, 05/11/2009 - 10:09
You can do:
sh spanning-tree | inc P2p Edge
The results that you get back are the ones that have "spanning-tree portfast" configured on their interfaces.
HTH,
John
cisco steps Mon, 05/11/2009 - 10:13
Jhon,
I put in the command and the result is noting
sw#sh spanning-tree | i P2p edge
sw#
John Blakley Mon, 05/11/2009 - 10:21
Oh, and "edge" has a capital "E"
try again with:
sh spanning-tree | i P2p Edge
You may still not have anything though.
lamav Mon, 05/11/2009 - 10:17
Hi:
Depending on the switch you are using, you should be able to see the portfast configuration under each switch port when you do a "sh run".
For example:
interface FastEthernet1/0/25
description VLAN_54_sw_port
switchport
switchport access vlan 54
switchport mode access
no ip address
no mdix auto
Victor
John Blakley Mon, 05/11/2009 - 10:20
And as Victor said, you can manually look through all of the interfaces. You may not have it enabled at all on any of the interfaces.
John
cisco steps Mon, 05/11/2009 - 10:34
here is my config
sw#sho int fa0/2
FastEthernet0/2 is up, line protocol is up
Hardware is Fast Ethernet, address is 000b.5f51.fec2 (bia 000b.5f51.fec2)
MTU 1500 bytes, BW 100000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Last input never, output 00:00:01, output hang never
Last clearing of "show interface" counters 10w5d
Queueing strategy: fifo
Output queue :0/40 (size/max)
22517472 packets input, 339072620 bytes, 0 no buffer
Received 79356 broadcasts, 0 runts, 0 giants, 0 throttles
3 input errors, 3 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
50344603 packets output, 457267010 bytes, 0 underruns
sw#sho spanning-tree active
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 24577
Address 000b.5f51.f0c0
Cost 19
Port 23 (FastEthernet0/23)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address 000b.5f51.fec0
Aging Time 300
Interface Port ID Designated Port ID
Name Prio.Nbr Cost Sts Cost Bridge ID Prio.Nbr
Fa0/1 128.1 19 FWD 19 32769 000b.5f51.fec0 128.1
Fa0/2 128.2 19 FWD 19 32769 000b.5f51.fec0 128.2
Fa0/3 128.3 19 FWD 19 32769 000b.5f51.fec0 128.3
Fa0/4 128.4 19 FWD 19 32769 000b.5f51.fec0 128.4
Fa0/5 128.5 19 FWD 19 32769 000b.5f51.fec0 128.5
Fa0/6 128.6 19 FWD 19 32769 000b.5f51.fec0 128.6
Fa0/7 128.7 19 FWD 19 32769 000b.5f51.fec0 128.7
Fa0/8 128.8 19 FWD 19 32769 000b.5f51.fec0 128.8
Fa0/9 128.9 19 FWD 19 32769 000b.5f51.fec0 128.9
Fa0/10 128.10 19 FWD 19 32769 000b.5f51.fec0 128.10
Fa0/11 128.11 19 FWD 19 32769 000b.5f51.fec0 128.11
Fa0/12 128.12 19 FWD 19 32769 000b.5f51.fec0 128.12
Fa0/13 128.13 19 FWD 19 32769 000b.5f51.fec0 128.13
Fa0/14 128.14 19 FWD 19 32769 000b.5f51.fec0 128.14
Fa0/15 128.15 19 FWD 19 32769 000b.5f51.fec0 128.15
Fa0/16 128.16 19 FWD 19 32769 000b.5f51.fec0 128.16
Fa0/18 128.18 19 FWD 19 32769 000b.5f51.fec0 128.18
Fa0/22 128.22 19 BLK 19 28673 000b.5fae.c080 128.22
Fa0/23 128.23 19 FWD 0 24577 000b.5f51.f0c0 128.23
John Blakley Mon, 05/11/2009 - 10:37
I'm going to "assume" that you don't have spanning-tree disabled on any of these ports. Now back to your original problem of "delay in audio", I highly doubt that would be a problem with spanning-tree to begin with. What are they using for audio? Are these phones, video conferencing devices, soft phones? I could be an issue with QoS.
HTH,
John
cisco steps Mon, 05/11/2009 - 10:46
a call comes to DMX 100 as x25 traffic then it get carry on to voice front node and then get converted to tcp and then gets connected to CISCO as 5350 voice getway the is connected to a LAN switches that all wrkstation are connected too. Hope this helps
Thanks again
Jon Marshall Mon, 05/11/2009 - 10:38
Try looking at the output of
"sh run interface fa0/2"
and see if has "spanning-tree portfast" in the config.
Jon
cisco steps Mon, 05/11/2009 - 10:41
interface FastEthernet0/2
no ip address
no logging event link-status
John Blakley Mon, 05/11/2009 - 10:43
Well, there goes my assumption :)
Is this the only port that you are concerned with? If you need to see all, just look through "show run."
HTH,
John
cisco steps Mon, 05/11/2009 - 10:49
John , That means port fast is enabled if I see it on all the interfaces. right ?
cisco steps Mon, 05/11/2009 - 10:50
Thanks again
