Unity Connection 7 transfer to VM directly
May 11th, 2009
Hello Guru,
I do check "Use Last (Rather than First) Redirecting Number for Routing Incoming Call " on Unity Connection.
I configured *+4 digit extension to transfer to VM directly without rining. it doesn't work, the default openning greeting plays. shown on the debug, the last-redicted number is "*2000" (use DN 2000 as example), if I configure an alternate extension *2000, it will work, but I don't want to do that. Unity Connection should see the last redirect DN is 2000 instead of *2000
however, if I do un-check the "Use Last (Rather than First) Redirecting Number for Routing Incoming Call", it is working
for other seperate task, I need to check "Use Last (Rather than First) Redirecting Number for Routing Incoming Call "
so please provide some clue on this
THanks
