Static addresses per user in ASA
Answered Question
May 11th, 2009
I originally set up a pool of addresses for my remote VPN users in the ASA. Now I have run into a couple of scenarios where I need the user to get the same address every time he logs in. Every time John Doe logs in I don't want him to get an address out of my default pool I want him to get a static address and get the same one every time. How would you do this. Thanks in advance for any help.
Correct Answer by nomair_83 about 7 years 9 months ago
hostname(config)# username name attributes
hostname(config)# username anyuser attributes
hostname(config-username)# vpn-framed-ip-address x.x.x.x
hostname(config-username)# vpn-framed-ip-netmask x.x.x.x
Overall Rating: 5 (1 ratings)
nomair_83 Mon, 05/11/2009 - 10:46
There is user specific configuration available in ASA so u can manually assign the user values like ip and other things.
srroeder Mon, 05/11/2009 - 10:53
I saw how to assign things like webvpn attributes, port forwarding and smart tunnels but I didn't see where or how to assign IP addresses.
Correct Answer
nomair_83 Mon, 05/11/2009 - 11:02
srroeder Mon, 05/11/2009 - 11:20
Perfect, just the command I was looking for, thanks for your help.
