Cisco 877W with IPoEoATM
ggovotsis
Hello Everybody,
Up till Friday the 8th of May in one of our remote locations we had BT as ISP and the 877W was working fine.
We change the provider to “Be Un limited” and since then we are unable to configure the 877W.
Below is a guide to Be* members wanting to use a 3rd party modem/router.
Who is this guide for?
For all Be* members configuring and wanting to use a 3rd Party Modem to connect to our broadband service.
“Be* technical support can only provide help for the Bebox and support for connection/speed problems to customers using the BeBox. It is necessary for the Bebox to be connected and the issue reproduced before raising a ticket or contacting support.”
Guide:
In order to use a 3rd party modem it has to be compliant with ADSL2+ service (has to support g.dmt.992.5 Annex A/Annex M(for BE* Pro members only) modulation)
If you have any such device that you feel more comfortable with, you will need to input the
following values:
1) vci=101 and vpi=0.
2) ADSL bridging should enabled (as per RFC 1483).
3) When configuring the WAN (DSL interface), you would get an option asking whether your ISP authenticates with user/pass or not - you have to choose NO in there, as we require no username and/or password for access to our network.
4) Connection type is IPoEoATM.
5) Multiplexing is LLC-based. If you are able to choose the LLC type it should be set to SNAP.
This should be sufficient for you to set up any 3rd party modem with our service. For more information in regards to third party modems, please refer to our forum where you can find solutions and opinions from fellow-members using third party hardware.
Please note that our hotline agents do not support third party hardware and can only give settings provided above.
The old configuration of the 877W is:
boot system flash c870-advipservicesk9-mz.124-6.T2.bin
interface ATM0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no snmp trap link-status
pvc 0/101
dialer pool-member 1
protocol ppp dialer
interface Dialer0
no ip address
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication ms-chap callin
ppp chap hostname xxx@btbroadband.com
ppp chap password 7 xxx
ip route 0.0.0.0 0.0.0.0 Dialer0
Can somebody help me to configure the 877W to work with the new ISP?
I also attach a user.ini file that is the current configuration of the new ISP's Modem Router.
George Govotsis
2 Accepted Solutions
Giuseppe Larosa
Hello George,
RFC1483 bridged means that ethernet frames are bridged over the ATM/ADSL.
The router has to behave as a bridge with one interface that is the lan interface and one that is the ATM.
The specificity of 877 is to use an SVI Vlan1 interface instead of eth0/0 of older routers.
I guess you would like to access the device remotely so you need IRB integrated routing and bridging
ip routing
bridge 1 protocol ieee
bridge 1 route ip
! these for all FE ports
! that are members of vlan1
int vlan1
no ip addr
bridge-group 1
int atm0
no shut
int atm0.1 point-to-point
no ip addr
bridge-group 1
pvc 0/101
enc aal5snap
! virtual L3 interface for bridge-group 1
interface BVI1
ip address dhcp
no shut
ip route 0.0.0.0 0.0.0 bvi1
notes:
I'm not sure the config of BVI is correct for you ISP.
note2:
if the ios image allows to use a second vlan (vlan2)
you can have vlan2 configured as ip nat inside and BVI as ip nat outside
you can associate some FE port to vlan2 as:
int fasx/y
switchport
switchport mode access
switchport access vlan2
see
for RFC1483 bridged
http://www.cisco.com/en/US/tech/tk39/tk48/technologies_configuration_example09186a008009455f.shtml
for bridging on vlans on 877
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/wireless.html#wp999748
Hope to help
Giuseppe
Have you tried "atm route-bridged" as well ?
Please do not low rate posts without a valid reason.
6 Replies 6
paolo bevilacqua
Remove PPP, it is not needed.
Configure ip address or dhcp under subif, together with "atm route-bridged".
Giuseppe Larosa
Hello George,
ip routing
bridge 1 route ip
int vlan1
no ip addr
bridge-group 1
int atm0
no shut
no ip addr
bridge-group 1
pvc 0/101
enc aal5snap
interface BVI1
ip address dhcp
no shut
notes:
note2:
int fasx/y
switchport
see
for RFC1483 bridged
Hope to help
Giuseppe
Giuseppe,
You do not necessarily need IRB. Atm route-bridged provides an easier alternative.
ggovotsis
Dear All,
Thanks for your replies.
I found through the IRC of Be the following config that I implemented
single static IP
version 12.3
no service pad
hostname c837-be*
boot-start-marker
boot-end-marker
enable secret cisco
no aaa new-model
ip subnet-zero
bridge irb
interface Ethernet0
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
hold-queue 100 out
interface ATM0
no ip address
bridge-group 1
pvc 0/101
encapsulation aal5snap
interface BVI1
ip address [static ip] [subnet mask]
ip access-group 101 in
ip nat outside
ip nat inside source list 1 interface BVI1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 [gateway]
no ip http server
no ip http secure-server
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 101 permit ip any any
bridge 1 route ip
line con 0
no modem enable
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 123
login
scheduler max-task-time 5000
end
and it resolve the issue.
George Govotsis
Hello Paolo, George
Paolo is right RBE can be a good solution as well, indeed has been developed for this kind of scenarios.
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t2/feature/guide/dtatmrbe.html#wp1023284
I'm more used with IRB because RBE had been introduced later and because I have little experience with it.
Hope to help
Giuseppe
