DMVPN and Static IPSEC tunnels on the same router
May 11th, 2009
I was curious if anyone has had any experience running DMVPN and static IPSEC crypto maps on the same Router(s). We are trying to save money by consolidating the network and this was considered as an option to eliminate redundant hardware. I Have a pair of 3845s which act as the hub location with about 50-60 2800s as spokes. I have it working on our lab network and things seem to be fine. I was just wondering if anyone had any experience with a similar set-up. Your feedback is appreciated!
ivillegas Fri, 05/15/2009 - 09:39
Yes it is possible to run DMVPN and static IPSEC crypto maps on the same Router.
Check the URL: DMVPN and Easy VPN Server with ISAKMP Profiles Configuration Example:
Dynamic Multipoint IPsec VPNs (Using Multipoint GRE/NHRP to Scale IPsec VPNs):
